How do I make controller reference new SSL cert and not the expired one?
I purchased a new SSL cert and uploaded it. I can see the old expired cert and the new one. My controllers are referencing the old expired cert. How do I make my controller reference the new cert? Any help would be greatly appreciated. I included a print screen of the gui page that i'm on.
Re: How do I make controller reference new SSL cert and not the expired one?
Under general, you'll see the captive portal certificate option. Select the cert from the drop down.
Tim Cappalli | Aruba Security
