How do i decrease the speed of 11n to less than that of the AP's physical connection?
My users laptops are connecting at higher then 100mbps, which is all good but their laptops are choosing this link over their LAN as the switches are only 100mbps, is there a way i can reduse this as the AP's interface is also conencted to a 100mbps port. i would much prefer to use LAN then WLAN when dual homed
Thanks in advance
Re: How do i decrease the speed of 11n to less than that of the AP's physical connection?
There's really no way to do what you are asking. The best solution would be to enable wireless/LAN switching in the BIOS so that only one is active at a time.
Tim Cappalli | Aruba Security
Thanks in advance
You should only use 20mhz channels in the 5ghz spectrum, if that is the case.  If you are using a controller-based AP, the command is:
config t
rf arm-profile "default" 40MHz-allowed-bands "None"
 Use the "route print" command on the commandline of  your Windows computer to confirm that the computer will prefer the Wired over the wireless interface.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Trusted Contributor I
Will pile on some additional suggestions:
If I remember correctly, OnGuard has a function that allows you to disable wifi if the wired NIC is active.  That's an option if you have ClearPass + OnGuard.
You can manipulate the metric for Window's network connections in the TCP/IP properties.  Not ideal, but I've used this before for dual-connected devices.
If a reply adequately addresses your issue, please click on the "Accept as Solution" and "Give Kudos" button so this information can benefit other users.
you can set the priority of the interfaces in windows 7 at least, see for example:
http://support.microsoft.com/kb/2526067
http://levynewsnetwork.wordpress.com/2011/12/01/windows-7-default-internet-connection-choice/
Not to be pushy but like I said before, all you need is to do is have 20 mhz channels enabled on your wireless.  The "route print" command on your Windows PC will tell you the priority of the interfaces.  Here is the association of a Windows 7 device connected to a 40 mhz channel:
(192.168.1.3) #     show ap association client-mac 84:3a:4b:34:dd:2c
The phy column shows client's operational capabilities for current association
Flags: A: Active, B: Band Steerable, H: Hotspot(802.11u) client, K: 802.11K client, R: 802.11R client, W: WMM client, w: 802.11w client
PHY Details: HT   : High throughput;      20: 20MHz;  40: 40MHz
             VHT  : Very High throughput; 80: 80MHz; 160: 160MHz; 80p80: 80MHz + 80MHz
             <n>ss: <n> spatial streams
Association Table
Name        bssid              mac                auth  assoc  aid  l-int  essid     vlan-id  tunnel-id  phy             assoc. time  num assoc  Flags  Band steer moves (T/S)
Office-225  9c:1c:12:90:5d:91  84:3a:4b:34:dd:2c  y     y      2    100    ACME-TLS  1        0x10017    a-HT-40sgi-2ss  1m:49s       1          WAB    0/0
..snip
 Here is the ipconfig for that device: .121 is the wireless interface and .92 is the wired.
Wireless LAN adapter Wireless Network Connection:
   Connection-specific DNS Suffix  . : gateway.2wire.net
   IPv4 Address. . . . . . . . . . . : 192.168.1.121
   Subnet Mask . . . . . . . . . . . : 255.255.255.0
   Default Gateway . . . . . . . . . : 192.168.1.254
Ethernet adapter Local Area Connection:
   IPv4 Address. . . . . . . . . . . : 192.168.1.92
 Below is the route print from the Windows PC, which indicates that Windows will treat both interfaces at the same metric of 20 for the default route 0.0.0.0, which likely will lead to the issue the OP is now experiencing:
IPv4 Route Table
Active Routes:
Network Destination        Netmask          Gateway       Interface  Metric
          0.0.0.0          0.0.0.0    192.168.1.254    192.168.1.121     20
          0.0.0.0          0.0.0.0    192.168.1.254     192.168.1.92     20
        127.0.0.0        255.0.0.0         On-link         127.0.0.1    306
        127.0.0.1  255.255.255.255         On-link         127.0.0.1    306
  127.255.255.255  255.255.255.255         On-link         127.0.0.1    306
      192.168.1.0    255.255.255.0         On-link     192.168.1.121    276
      192.168.1.0    255.255.255.0         On-link      192.168.1.92    276
     192.168.1.92  255.255.255.255         On-link      192.168.1.92    276
    192.168.1.121  255.255.255.255         On-link     192.168.1.121    276
    192.168.1.255  255.255.255.255         On-link     192.168.1.121    276
    192.168.1.255  255.255.255.255         On-link      192.168.1.92    276
        224.0.0.0        240.0.0.0         On-link         127.0.0.1    306
        224.0.0.0        240.0.0.0         On-link     192.168.1.121    276
        224.0.0.0        240.0.0.0         On-link      192.168.1.92    276
  255.255.255.255  255.255.255.255         On-link         127.0.0.1    306
  255.255.255.255  255.255.255.255         On-link     192.168.1.121    276
  255.255.255.255  255.255.255.255         On-link      192.168.1.92    276
Just changing it to 20mhz channels:
Association Table
Office-225  9c:1c:12:90:5d:91  84:3a:4b:34:dd:2c  y     y      1    100    ACME-TLS  1        0x10017    a-HT-20sgi-2ss  49s          1          WAB    0/0
..snip
 ...also changes the priority:
C:\Users\cjoseph>route print
..snip
IPv4 Route Table
Active Routes:
          0.0.0.0          0.0.0.0    192.168.1.254    192.168.1.121     25
      192.168.1.0    255.255.255.0         On-link     192.168.1.121    281
    192.168.1.121  255.255.255.255         On-link     192.168.1.121    281
    192.168.1.255  255.255.255.255         On-link     192.168.1.121    281
        224.0.0.0        240.0.0.0         On-link     192.168.1.121    281
  255.255.255.255  255.255.255.255         On-link     192.168.1.121    281
 the ethernet or .92 priority reduces to 20, so the traffic will always go out that interface.
