How do i query wifi controller for probe requests forwarded by APs using SNMP utility ?
Any device looking for wireless network transmits probe requests to find nearby access points . The access points in turn forwards the probes received to wifi controller.
Using SNMP I can query any OID(object identifier) from MIB(management information base) of a wifi controller.    Basically my question is how to query the wifi controller for probe requests ? What is the OID I should query for ?
Re: How do i query wifi controller for probe requests forwarded by APs using SNMP utility ?
Unfortunately, there is no OID for probe requests.
