How do you delete old entries out of an Aruba controller 3600 AP database?
I have several RAP 5 devices provisioned in an Aruba 3600 controller that we have been decommisioning and repurposing for new locations.  When I go into the GUI, I would delete it out of the whitelist, enter the new information and provision the profile information and it would come online.  However in the CLI, when I do a show AP database, the old entry still exists along with the new one.   Is there a more efficient way to delete old entries so that it wipes all information accross the tables and databases?
Re: How do you delete old entries out of an Aruba controller 3600 AP database?
There is a clear command in the CLI.  However, in the UI, go to Monitoring --> access points.  Find the entries for the old RAPs and you can click the Clear button all the way to the right in the table
Seth R. Fiermonti
Consulting Systems Engineer - ACCX, ACDX, ACMX
Email: seth@hpe.com
If you found my post helpful, please give kudos
Frequent Contributor II
clear gap-db wired-mac <MAC of AP> to do it from the CLI
If you found my post helpful, please give kudos!
Good morning,
I have a similar issue but with a twist. I have removed the AP from the GUI and from CLI, but when I go back into the controller GUI and look, the AP is still present. Has anyone seen this issue before?
Thanks in advance!
it needs to be removed from the master
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Thanks for the reply. I did confirm that the AP was deleted from the Master controller.
