How does Clientmatch move to the optimum radio?
  • 1.  How does Clientmatch move to the optimum radio?
    Posted Jun 23, 2014 08:18 AM
    When ClientMatch discover a client below threshold defined in adatative radio management settings, how does client moves to optimus radio?
    I found some information about Patent 8401554, does wrong AP hide the SSID to the client in probe request? Is it possible that clients moves to the optimum AP by 802.11v protocol?
    I appreciate all your help,
  • 2.  RE: How does Clientmatch move to the optimum radio?
    Posted Jun 23, 2014 08:19 AM
    If the client supports 11v it uses it.
    If not, it de-auths the client from the AP that it is "stuck" to.
  • 3.  RE: How does Clientmatch move to the optimum radio?
    Posted Jun 23, 2014 08:51 AM
    I am sorry, but I don't know what is "de-auths". is it a kind of  extenisble authentication protocol (EAP)?
  • 4.  RE: How does Clientmatch move to the optimum radio?
    Posted Jun 23, 2014 08:56 AM
    Deauthentication frames are an 802.11 management frame.
    "Deauthentication frame: A station sends a deauthentication frame to another station if it wishes to terminate secure communications."
  • 5.  RE: How does Clientmatch move to the optimum radio?
    Posted Jun 24, 2014 03:00 AM
    Ok thanks,
    and when client has been rejected from wrong AP by de-auths, what happen when does the client conected to another AP?  How does client conect to another AP in hardly interrupting?
    Thanks for all,
  • 6.  RE: How does Clientmatch move to the optimum radio?
    Posted Jun 24, 2014 06:56 AM
    Please speak to your Aruba sales representative for a full explanation.
  • 7.  RE: How does Clientmatch move to the optimum radio?
    Posted Aug 25, 2014 07:39 AM
    I try to analize the virtual beacon reports  of client match. Can you tell the relation bettwen dBm to  RSSI (received signal strength indicator)?
    Thanks for all,
    Xavi
  • 8.  RE: How does Clientmatch move to the optimum radio?
    Posted Jun 23, 2014 09:00 AM
    @Xavi wrote:
    Xavi,
    Not all clients support the 802.11v protocol.  Please see the ClientMach technical brief here:  http://www.arubanetworks.com/pdf/solutions/TB_ClientMatch.pdf
