Hi
How does a Controller manage config files between diffrent partitions? Reason being is I have a partition running 6.3.1.8 and the other on 6.3.1.1. My config is saved in default.cfg
When I boot into 6.3.1.8 quite a large portion of config is missing, however when I boot my partition with 6.3.1.1 the config loads as expected.
Does the config files live on a third partition, do they live in on a flash ROM or is there a copy of each file in each partition???
Kind Regards
Hendrik
