How does rouge AP containment work?
we're using a aruba3200 controller with just a few ap attached. I can see that the system detected several suspected rouge AP. How can i handle them. I found the "containment" option within the IDS section but what exactly will happen when the controller tries to contain the rouge AP's? Additionally can i add some kind of notification when the system detects a new rouge AP?
Kind regards
Re: How does rouge AP containment work?
Please start with the section here:  http://www.arubanetworks.com/techdocs/ArubaOS_63_Web_Help/Web_Help_Index.htm#ArubaFrameStyles/New_WIP/Monitoring_Dashboard.htm
The controller can send an snmp trap or syslog message when it finds a rogue access point.
Can I do this (rouge AP containment) without RF Protect license?
Daniel.
Yes.  Please see here:  http://www.arubanetworks.com/techdocs/ArubaOS_64x_WebHelp/Web_Help_Index.htm#ArubaFrameStyles/New_WIP/New_WIP.htm%3FTocPath%3DWireless%2520Intrusion%2520Detection%7C_____0
