can anybody help me to find the signal strength in dbm for an running Accesspoint 105 with ARM enabled.
I have used the folloowing cli command -- #show ap arm history ap-name xxxx-ap1
Output:
Interface :wifi0
ARM History
Time of Change Old Channel New Channel Old Power New Power Reason
2013-10-25 16:04:54 132+ 36+ 24 24 I
2013-10-21 13:11:40 132+ 132+ 21 24 P+
2013-10-21 13:07:12 132+ 132+ 18 21 P+
I: Interference, R: Radar detection, N: Noise exceeded, E: Error threshold exceeded, INV: Invalid Channel, G: Rogue AP Containment, M: Empty Channel, P+: Increase Power, P-: Decrease Power, OFF: Turn off Radio,
What is the value from Old/New Power for a definition -- is that DB, DBM, mWatt ............
Many thanks for your help.
Cheers Roland
