Frequent Contributor II
How many 2 Megapixel camera can be on 1 point to point link using MST200?
I want to create a point to point and point to multipoint solution the distance is diffrence from 30 to 100 meters so I want to know how many cam can be based on 1 link point to point or point to multi-point based on   MSR2K and 2x MST200
Re: How many 2 Megapixel camera can be on 1 point to point link using MST200?
What channel bandwidth between the APs? What is the FPS and compression codec of each camera?
Jerrod Howard
this is camera specs below:
Image Sensor     1/2.7" Progressive scan CMOS 2 Megapixel
Pixels - Total     1920(H) x 1080(V)
Col/B&W     On/Off/Auto, IR-cut filter removable (ICR)
Sensitivity Colour     0.5 Lux@F1.4 (IRE50), 0.2 Lux@F1.4 (IRE30)
Sensitivity B&W     0.1 Lux@F1.4 (IRE50), 0.02 Lux@ F1.4 (IRE30)
Lens Drive Type     Auto iris (DC)
Lens Focal Length     3.0 ~ 10.5 mm
Viewing Angle     approx. 94°(w) ~ 27° (t)
IR LED     23 pcs., 90° beaming angle
Max. IR Distance     15/25 m (according to scene reflexion)
WDR     D-WDR (Digital wide dynamic range)
BLC Back Light     On/Off
WDR     High/Medium/Low
Digital Noise Reduction (DNR)     On/Off (Adaptive 3D + 2D)
Motion Detection     On/ Off/ Sensitivity/ Area setting
Tampering Alarm     On/Off
Privacy zones     5 zones, rectangle
White Balance     ATW, AWB, Manual
Digital Zoom     Yes
Shutter Speed     1 ~ 1/10.000 sec
Alarm Inputs     1
Alarm Outputs     1
Web Browser     MS Internet Explorer 6.0 (or higher), Firefox, Google Chrome, Safari
Number of Clients     Up to 20 simultaneously
Video Compression     H.264, MJPEG
Video Resolution     Full HD 1080p/ SXGA/ HD 720p/ XGA/SVGA/ D1/ VGA/ CIF/ QCIF
Video Streaming     Quad stream: max.: H.264+H.264+H.264+H.264 or H.264+H.264+H.264+MJPEG
Network Protocol     IPv4/v6, TCP/IP, UDP, RTP, RTSP, HTTP, HTTPS, DHCP, PPPoE, UPnP, SMTP, ICMP, IGMP, SNMP, IEEE802.1x, QoS, ONVIF, ARP
SD memory     supports up to 32 GB capacity of micro SD/SDHC memory
Recording Types:     on Micro SD/SDHC CARD: Single Image Recording (JPEG), Video(AVI, LCK) on NAS: Video (AVI)
Alarm Event     Alarm Input, Motion Detection or Schedule: Image Transfer or Alarm Message by FTP, Image Transfer or Alarm Message by E-mail, Recording on SD-Card, enable Alarm Output and send HTTP Notification
Audio Compression     G.726, G.711
So figure each camera can use anywhere from 4-7Mbps depending on framerate. So from there, you have to identify what channel bandwidth you will be running.
PtP: HT20 would be around 6-8 camera feeds, HT40 would be around 10-14 camera feeds.
PtMP: HT20 would be around 4-6 camera feeds, HT40 would be around 8-12 camera feeds.
All of that is ballpark because there are just too many variable to contend with, so until you know and have measured the bandwidth of the actual camera, that should be a reasonable assumption. Note that if you are not doing any kind of buffering on the camera, you will likely have some level of jitter with that kind of video load over a PtP link.
Jerrod Howard
Thank you for the helpfull answer I actaully planning to use HT20 to avoid interference on HT40
