How migrate from 7005 controller to a 7205?
Hi, i would like to know if there is a way to migrate the config, license etc automatically from a controller 7005 to a 7205. If there is not please tell me which could be the best procedure to do this.
Re: How migrate from 7005 controller to a 7205?
The best to do this is to make your 7200 controller a local to the 7005 so it can grab the config and then you can make a master.
The licensing transfer needs to be done on the licensing site.
Get Outlook for iOS
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Ok i´m going to try this but like in a month. Thanks!
