Contributor I
How to activate IAP-275 once it's moved to a controller
I converted an IAP-275 from and instant AP to a mobility controller with all of my other APs (225s).  Now that I have it in the controller, it is flagged with 2I and I cannont seem to get the radios enabled on it.
Re: How to activate IAP-275 once it's moved to a controller
On the commandline of the controller, type "show log system 50" to see if you can get a clue why the AP would not come up.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Contributor I
I am unable to get it to respond to ssh now that it is on the controller.
You should SSH into the controller to get that log..
Contributor I
ok here is what it shows but I am not sure what it means
Is there a firewall between that AP and the controller?
Contributor I
No it is not.
Contributor I
and i verified it is not a licensing issue.
Is it in the same ap-group as other access points?
Contributor I
Yes it is but they are models AP-225.  This one is a AP-275.
