How to block bit torrent on the 7020 controller.
How to prevent users from downloading files from torrents on the 7020 controller.
Aruba
Re: How to block bit torrent on the 7020 controller.
If you have Deep Packet Inspection (DPI) enabled and own the PEF license, you can set rules to block peer to peer sharing; including bit torrent.
An example configuration in policy:
ip access-list session block-p2p
   user any app bittorrent deny
   user any appcategory peer-to-peer deny
However, be sure to enable DPI in the Global Firewall settings as well as the individual role.
ACCX | ACDX | ACMX
