How to cap bandwidth on guest open ssid
Hi, I have recently set the guest wifi SSID to open, however, am trying cap the bandwidth on the SSID, can anyone assist me with appropriate steps to take or  guide to read from
Thanks.
Re: How to cap bandwidth on guest open ssid
