Contributor I
How to check campus AP firmware version?
Hi, how to check campus AP firmware version? Please advise. Thanks.
Re: How to check campus AP firmware version?
It will be the same as the controller's code version.
Tim Cappalli | Aruba Security
If the AP is up, it will match what ever the controller is, you can also do a 'show ap image version' on the controller.
Jerrod Howard
Contributor I
Thanks a lot all of you.
Airwave shows two different versions of software on the Aruba AP's. My controller is at 6.4.3.7, while all AP's except 5 are the same version. Airwarve shows 5 Aruba-225's at 6.4.3.6. Is airwave gettting wrong information?
