Frequent Contributor II
How to clear configuration on Mobility Master
is there a way to delete all the configuration from the md level down to all the groups and folders created on the MM?
basically I want to start from scratch but without configuring the MM primary/master to create a new structure with my root template and very few groups per region.
After being working on with ArubaOS 8.0 and adding configurations to different levels I realize it is very easy to lose the visibility of what is configured where so I want to create documentation to avoid confusion for all our engineers.
Re: How to clear configuration on Mobility Master
Slightly different problem for me, I somehow got an IKE policy set in the root and I cannot get rid of it.
Hoping that on the roadmap is a way to visually indicate if a setting is inherited from the parent or is set on the node being viewed.
