Occasional Contributor I
How to configure 93H port in bridge mode?
I would like to enable the switch ports on AP 93H and place them on the same network as it's eht0.
I have enabled the ports and created a profile in bridge mode.
When connect a PC to the port, I see ARP from network, but the computer cannot get IP.
What am I missing?
Thank you for your help.
Re: How to configure 93H port in bridge mode?
Did you make the ports trusted?
Zach Jennings
It will not let me since I set it to be bridge mode.
Sorry, I missed that. Is the switchport mode set to access? And access mode vlan set to 1?
If that's all set, they you need to look at the AAA profile for the port.
Zach Jennings
