How to configure LACP on AP225 in a Fast failover environment
Hi All,
We have a deployment where we are trying to setup LACP on the dual ports of an AP225.
We are wondering where to setup the Link Agg as it seems that both the ports are up on the AP but the port channel is showing as N/A when we believe to have configuired this under
Configuration-> all Profiles -> AP -> AP LACP LMS map information
I am just unsure of exactly the configuration to make the port channel live.
The controller environment is setup as
2 controllers in active/Standby with 2 local controllers connecting to the VIP of the VRRP and using Fast Failover,
Sean
Re: How to configure LACP on AP225 in a Fast failover environment
After you configure the LACP map, no other configuration is necessary. Is your upstream switch configured for LACP?
Tim Cappalli | Aruba Security
