How to connect a iap 275 ?
I needed help for install a iap 275.
On a iap 275 we have 2 Network interfaces  WAN & LAN.
It's is possible to know how install this product ? (Cabling)
This is sufficient for work to use only Wan port or we have need to connect all port  wan and lan ?
Ben.
Re: How to connect a iap 275 ?
Use E0 (left). This is the port that will accept PoE power.
http://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Method/attachment/Default.aspx?EntryId=13904
Tim Cappalli | Aruba Security
Ok for powering.
The port LAN it's for what ? I have need or not ?
Thans for your response.
Ben.
No, you don't need that port unless you are providing wired access to a client device.
Thanks For Support .
Ben
