Occasional Contributor I
How to connect wired printer to a wireless network with TP-Link TL-WR802N router.
Hello all.
I have wifi campus network based on 7220 controller and AP325. Now I need to connect a wired printer to the wireless. We already have a TP-Link TL-WR802N and I configured it as a client but I think I need to change some settings on controller because the printer doesn't receive IP from corporate DHCP server. Any ideas?
Thanks.
Best,
A
Re: How to connect wired printer to a wireless network with TP-Link TL-WR802N router.
According to page 168 of
http://static.tp-link.com/res/down/doc/TL-WR802(UN_V1_UG.pdf
"When you choose the Smart IP (DHCP) mode, the DHCP Server function will be disabled."
It sounds good but I want to use corporate DHCP server.
What I can see at controller are two entries with the same Ethernet address.
Thanks.
A
