Frequent Contributor I
How to console into AP305?
Hi All, working with an AP305 for the first time. I noticed that there is no console port anymore, and that it is replaced by a 4 pin connector hidden behind a rubber cover. How do you access the console using this connector?
-N
Re: How to console into AP305?
You need the following cable:
Part Number Description
JW071A AP-CBL-SER AP Proprietary DB9 Female Serial Adapter Cable
http://www.arubanetworks.com/assets/og/OG_AP-300Series.pdf
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Perfect, thanks.
N
