Occasional Contributor I
How to create a fake Radar signal on controler/AP using CLI ?
I wanted to generate fake radar signal on Aruba contorller/AP using CLI commands, so that controller/AP will detect the radar pulse and announce a channel switch to client and move to new channel.
using Aruba 620 controller/AP134.
thx for your help.
Re: How to create a fake Radar signal on controler/AP using CLI ?
That is not possible.
Tim Cappalli | Aruba Security TME
Thx for your reply ..
Is there any other way to ask AP to switch over to any other channel (Channel switch announcement in Beacon/Action frame) ?
-VSK
Maybe introduce a wireless camera, something will eat up duty cycle.
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACMP
[If you found my post helpful, please give kudos!]
Getting an AP to switch channels due to interference or duty-cycle reasons, is a *COMPLETELY DIFFERENT* trigger than what causes a DFS trigger to occur. Simulating AP channel changes due to interference or duty cycle is easy (microwaves, cameras, etc). Triggering DFS will require access to specific radar-based trigger algorithms that the FCC sets. You can dig around Google and find the trigger thresholds, rates, etc.
Jerrod Howard
i know Triggering DFS radar signal with external equipment (ex: Agilent signal generator etc..).
But i wanted here .. whether Aruba is giving any debug CLI command to switch to Different signal by CSA announcement.
Cisco has this implementation:
Cisco#Debug dot11 dot11 1 dfs simulate <ch>
-Vsk
ah interesting, can't find such a command. you might want to add it to the idea portal and see if you get some support.
Any updates on this? Is a CLI command now available?
