How to disable the Proxy settings from specific SSID?
Re: How to disable the Proxy settings from specific SSID?
Is this for a Controller or Instant setup ?
Thank you
Victor Fabian
Lead Mobility Architect @WEI
I have already configured auto-proxy for guest ssid but now when i connect to guest ssid its giving me Internet access problem with Auto-detect proxy setting on Aruba Wireless SSID and if same i configured manually it works properly. please suggest.
If it is in transparent mode then you can follow the instructions here to apply it to the ACL under the user-role :
http://community.arubanetworks.com/t5/Controller-Based-WLANs/How-to-configure-Aruba-Controller-for-redirecting-traffic-to-the/ta-p/180598
Thank you
Victor Fabian
