Contributor I
How to: downgrade IAP firmware
We are facing trouble latest (early availability) firmware on our IAP103's can not work with Airwave. They are on customers site. We want to downgrade IAP's to a firmware version that is supported byAirwave. How can we do that?
It seems (using port forwarding) using Instant Webgui access - maintenance tab - brwose to pegasus file on pc and click on upgrade - nothing seems to change. It keeps on latest firmware after the reboot.
Any ideas?
Re: How to: downgrade IAP firmware
Under Groups > (IAP GROUP) > Firmware
You need to enable "Allow Downgrade Of Devices:"
Thank you
Victor Fabian
Lead Mobility Engineer @ Integration Partners
How do you do this from the terminal connection via putty?
This option is already selected but still unable to downgrade the IAP and getting below error message.
Failed: 6.5.1.5-4.3.1.6_61735 to 6.4.4.8-4.2.4.9_61734.
Its an IAP305
Could you help me on this ?
Minimum version of Instant for the IAP305 is 4.3.1.0
http://www.arubanetworks.com/assets/ds/DS_AP300Series.pdf
4.2.4.9 will not work.
Colin Joseph
Aruba Customer Engineering
