Occasional Contributor I
How to drop interferin​g network
I have Aruba620 connected with 4 AP and 1 air monitor, i need to drop the Interfering wireless network  so i reclassify them to Rogue but that not make them drop, any suggestion?
Thank you
MVP
Re: How to drop interferin​g network
DO you got WIP/RFP module installed ? if not - the rouge classify will not do nothing.
Kindly find the attached all licenses that i have.
thank you
MVP
OK .. u got RFPORTECT installed.
by "drop" - what do u mean? when u mark SSID as rouge...the controller will try to DOS the wired port of this AP and will also de-auth /trapit the users that trying to connect to it - but it still be will visable and will transmit.
MVP
Are those interference APS are  IN your network or its OUT your network?
If they are IN then yes you can kill them and to fin them you can use my manual  to clasiffy rogue APS with L3 rogue detection.
http://community.arubanetworks.com/t5/Unified-Wired-Wireless-Access/Tutorial-How-to-detect-Rogue-APS-with-L3-Rogue-Detection/m-p/156722
If they are OUT your network you should not drop them, i mean they are your neighbors APS and you should not do anything to their APS i mean thats not ethic :)
Alternetworks Corp
yes i mean by drop that "de-auth /trapit the users that trying to connect to it" but that not happened.
MVP
Do you mean your internal users trying to connect to external APS?which are not your APS?
Cheers
Carlos
Alternetworks Corp
Yes, correct
MVP
You need to activate this: Detect Valid Client Misassociation
Its on ap group--> ids Profile--->ids unauthorized device.
Cheers
Carlos
Alternetworks Corp
MVP
[ Edited ]
That client you are going to test you need that the client alrady have been associated with the your Aruba Wireless system.
The controller holds a Client table or something like that, and that way he knows which valid clients are trying to associate with a rogue ap or an ap which does not belong to your company.
Also your Ap in air monitor must be in range, and has the air monitor with the config.
Cheers
Carlos
Alternetworks Corp
