Regular Contributor I
How to enable AppRF
we´ve an 651er Controller with Software running.
How can I enable AppRF?
Or does AppRF not run on a 650er Controller? CPU to small?
Re: How to enable AppRF
AppRF is not supported on the 6x0 platform.
Tim Cappalli | Aruba Security
From the release notes:
Colin Joseph
Aruba Customer Engineering
