Anyone can teach how to enable external USB port in Aruba Controller 7005?
As figure below, it disable the external USB port while controller is startup.
What are you trying to use them for? The USB console port should work, but 4G uplink is not yet available.
I just need to backup configure file and manual upgrade the firmware.
Is the controller powered via AC power, 802.3af or 802.3at PoE?
The controller was powered by 802.3af PoE.
I was power up the controller via POE. Will controller auto disable USB if not enough power to controller?
Reboot Reason: AP rebooted Thu Jul 25 15:46:37 IST 2019; Unable to set up IPSec tunnel, Error:RC_ERROR_IKEV2_TIMEOUT
