Occasional Contributor I
How to ignore smart phones in Rapdids?
I would need a Rapids rule what ignores smart phones which are operating as an AP-mode. And there's lots of applications and OS features in iPhones and Androids that will get them to Unclassified list of Rapids.
It's time consuming to manually remove those devices from Unclassified list one by one and I don't see them as a threat.
What kind of rules have you used?
Re: How to ignore smart phones in Rapdids?
If you are running 6.x code on your controllers, you should be able to create a RAPIDS rule to look at the operating system. In the entry box, you can enter the operating systems you want to move to Unclassified.
Let me know if this works for you.
Zach Jennings
