How to integrate external Captive portal into aruba controller
I have a new Aruba project that request to integrate external captive portal with Aruba controller 7005. Customer want to provide a open wifi to their end user. This customer is a local stall that selling sport stuff. They have a own splash page.
Customer would like to integrate their own splash page into Aruba controller. This splash page does not have any authentication server. It just a normal apache server and the splash page only have term and condition information. End user agree the T&C then will allow internet access.
Why customer want to use their own splash page rather than aruba controller captive portal? This is because customer will change or update the splash page time to time. If there have any promotion or information, customer also will change their splash page. With using their own splash page, it will be easy for the customer.
Kindly advise how to integrate external captive portal that without authentication server to aruba controller.
Re: How to integrate external Captive portal into aruba controller
This should help get you started:
Tim Cappalli | Aruba Security
