Frequent Contributor I
How to make Aruba AP-207 work ? Only APboot no nand flash ?
I have one brand new aruba AP-207, I want to work with our controller 7024,but we get the followed information, are there anybody can tell me the reason ? Thanks
APBoot 2.1.4.11 (build 59208)
Built: 2017-04-13 at 18:41:18
Model: AP-207
CPU: BCM47452 revision: 3
Clock: 900 MHz, DDR rate: 533 MHz
DRAM: 255 MiB
Flash: Detected W25Q32FV: total 4 MiB
NAND: No NAND flash type found
NAND chip could not be initialized
0 MiB
PCIe0: RC, link up
dev fn venID devID class rev MBAR0 MBAR1 MBAR2 MBAR3
00 00 14e4 aa31 00002 02 00000004 00000000 00000004 00000000
Power: POE
Device nand0 not found!
Error initializing mtdparts!
Net: eth0
Radio: bcm43570#0, bcm47452#1
Reset: warm
FIPS: passed
Hit <Enter> to stop autoboot: 0
Checking image @ 0x0
Error, no UBI device/partition selected!
Invalid image format version: 0x801c0140
Checking image @ 0x2000000
Invalid image format version: 0x143c8ab2
eth0 up: 1 Gb/s full duplex
DHCP broadcast 1
DHCP IP address: 192.168.100.195
DHCP subnet mask: 255.255.255.0
DHCP def gateway: 192.168.100.222
DHCP DNS server: 192.168.100.222
DHCP DNS domain:
ADP multicast 1
Controller address: 192.168.100.60
Using eth0 device
TFTP from server 192.168.100.60; our IP address is 192.168.100.195
Filename 'armv7ns.ari'.
Load address: 0x4100000
Loading: #################################################################
743.2 KiB/s
done
Bytes transferred = 11516548 (afba84 hex)
Image is signed; verifying checksum... passed
SHA2 Signature available
Signer Cert OK
Policy Cert OK
RSA signature verified using SHA2.
Automatic boot of image at addr 0x04100000 ...
Uncompressing... done
[ 0.000000]
[ 0.000000] Aruba Networks
[ 0.000000] ArubaOS Version 8.3.0.0 (build 64659 / label #64659)
[ 0.000000] Built by p4build@pr-hpn-build09 on 2018-04-27 at 22:00:09 UTC (gcc version 4.7.2)
[ 0.000000]
[ 0.000000] Flash variant: default
[ 0.000000] MPCORE found at 18310000, SCTLR 0x10c53c7f ACTLR 0x00006040 CPSR 0x600001d3 SPSR 0x000001d3 PRRR 0xff0a81a8 NMRR 0x40e040e0
[ 0.000000] Memory: 256MB = 256MB total
[ 0.000000] Memory: 245812k/245812k available, 16332k reserved, 0K highmem
[ 0.000000] External imprecise Data abort at addr=0xde0daa4a, fsr=0xc06 ignored.
[ 0.000000] Found ST compatible serial flash with 64 64KB blocks; total size 4MB
[ 0.000000] MPCORE Global Timer Clock 34714Hz
[ 0.046000] CCA UART Clock Config: Sel=1 Ovr=1 Div=88
[ 0.046000] CCA UART Clock rate 40000000Hz
[ 0.048000] ACP (Accelerator Coherence Port) disabled
[ 7.102000] PCI: no core
[ 7.306000] PCI: scanning bus 0
[ 7.306000] PCI: Fixing up bus 0
[ 7.560000] PCIE1 link=1
[ 7.560000] PCIE1 switching to GEN2
[ 7.810000] PCIE1 link=1
[ 7.810000] PCI: Fixing up bus 0
[ 7.810000] PCI: Fixing up bus 1
[ 7.812000] pci 0001:00:00.0: BAR 8: assigned [mem 0x10000000-0x105fffff]
[ 7.812000] pci 0001:01:00.0: BAR 2: assigned [mem 0x10000000-0x103fffff 64bit]
[ 7.812000] pci 0001:01:00.0: BAR 2: set to [mem 0x10000000-0x103fffff 64bit] (PCI address [0x10000000-0x103fffff]
[ 7.812000] pci 0001:01:00.0: BAR 0: assigned [mem 0x10400000-0x10407fff 64bit]
[ 7.812000] pci 0001:01:00.0: BAR 0: set to [mem 0x10400000-0x10407fff 64bit] (PCI address [0x10400000-0x10407fff]
[ 7.868000] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 7.980000] Creating 1 MTD partitions on "bcmsflash":
[ 7.982000] 0x000000000000-0x000000400000 : "nor"
[ 7.984000] Northstar brcmnand NAND Flash Controller driver, Version 0.1 (c) Broadcom Inc. 2012
[ 7.986000] brcmnand: found no supported devices
[ 7.988000] UBI error: ubi_init: UBI error: cannot initialize UBI, error -2
[ 7.990000] i2c-springbank: using remapped base d0874060
[ 7.992000] mpcore_wdt mpcore_wdt: enabling watchdog.
[ 7.994000] ramzswap: num_devices not specified. Using default: 1
[ 7.996000] ramzswap: Creating 1 devices ...
[ 8.120000]
[ 8.120000] Starting Kernel SHA1 KAT ...Completed Kernel SHA1 KAT
[ 8.124000] Starting Kernel HMAC-SHA1 KAT ...Completed Kernel HMAC-SHA1 KAT
[ 8.218000] Starting Kernel DES KAT ...Completed Kernel DES KAT
[ 8.222000] Starting Kernel AES KAT ...Completed Kernel AES KAT
[ 8.224000]
[ 8.226000] Starting Kernel AESGCM KAT ...Completed Kernel AESGCM KAT
Populate AP type info
AP-type has_ble_support: BRCM_ONBOARD.
Domain Name: arubanetworks.com
[ 10.504000] UBIFS error (pid 300): ubifs_get_sb: cannot open "ubi2:ubifs", error -19
mount: Mounting ubi2:ubifs on /aruba/fs failed: No such device
Mounting ubifs failed
apfcutil: apfc_read failed: Cache uninitialized
Will reboot to mount ubifs
killall: nanny: no process killed
killall: sapd: no process killed
apfcutil: apfc_write failed: Cache uninitialized
SIOCSIFADDR: No such device
Sending SIGKILL to all processes.
Unmounting UBIFS failed. Please report this error (Invalid argument).
Please stand by while rebooting the system.
[ 20.014000] Restarting system.
Model: AP-207
DRAM: 255 MiB
0 MiB
PCIe0: RC, link up
Re: How to make Aruba AP-207 work ? Only APboot no nand flash ?
I suspect this will probably require an RMA, have you spoken to TAC?
ACMP, ACSA, ACDX #985
If my post addresses your query, give kudos:)
no suspicion required, this is 100% an RMA :)
Hi !
I had exactly the same problem.
Even though it sounds incredible, the incompatible console cable was the cause.
First I tested the cable with the CP2102 USB chip.
Then I tested the cable with the USB chip CH340G.
Both cables behaved equally (badly).
The original "AP-CBL-SER" cable contains only the MAX3232 voltage converter.
So, you need to use some USB / serial adapter (if you do not have a real serial port on your computer).
I hope this will help.
Lubos
