How to make mesh with Instant AP-225 and instant AP-205 with no controller?
  • 1.  How to make mesh with Instant AP-225 and instant AP-205 with no controller?
    Posted Mar 12, 2015 05:39 AM
    I have 2 instant AP 225 and 205 how can I mesh on instant OS?
    #AP225
  • 2.  RE: How to make mesh with Instant AP-225 and instant AP-205 with no controller?
    Posted Mar 12, 2015 06:21 AM
    Hi Friend,
    You can bring up a mesh link with IAP with the following method,
    1. Create cluster with IAP-225 and IAP-205 and let them sync with image and configuration
    2. Disable the extended SSID ( in the latest version 4.x, it is enabled)
    3. you will find both the IAPs as mesh portals.
    4. Remove the IAP from the Switch which you want to make mesh point and provide external power.
    5. After booting, there will be a mesh link between two IAPs.
    Hope I answered your query.
    Please feel free for any further help on this.
  • 3.  RE: How to make mesh with Instant AP-225 and instant AP-205 with no controller?
    Posted Mar 12, 2015 06:30 AM
    11ac access points do not currently support mesh. New code should be available shortly.
    Tim
  • 4.  RE: How to make mesh with Instant AP-225 and instant AP-205 with no controller?
    Posted Mar 12, 2015 07:35 PM
    OK thank you guys,
    so now I have 2 ETH ports in AP-225 ,can I take a cable from the free port and connect it to another AP?
  • 5.  RE: How to make mesh with Instant AP-225 and instant AP-205 with no controller?
    Posted Apr 09, 2015 01:57 AM
    Do you know when will be aproxymately implemented "MESH" for IAP 2xx?
    Thanks & best regards,
    Jan Masin.
  • 6.  RE: How to make mesh with Instant AP-225 and instant AP-205 with no controller?
    Posted Aug 08, 2015 01:59 PM
    Instant 6.4.3.1-4.2 is now available in Early Deployment with mesh support.
    https://support.arubanetworks.com/DownloadSoftware/tabid/75/DMXModule/510/EntryId/18363/Default.aspx
  • 7.  RE: How to make mesh with Instant AP-225 and instant AP-205 with no controller?
    Posted Aug 24, 2015 10:36 PM
    I try the Instant 6.4.3.1-4.2 code with 2pcs of Instant AP-205, but it's not working. Both 2.4GHz/5GHz LED in yellow steady.
    Is there any configuration need to setup? thanks!
    Best regards,
    Jeff
  • 8.  RE: How to make mesh with Instant AP-225 and instant AP-205 with no controller?
  • 9.  RE: How to make mesh with Instant AP-225 and instant AP-205 with no controller?
    Posted Aug 24, 2015 11:21 PM
    It's works now, thank you so much!
  • 10.  RE: How to make mesh with Instant AP-225 and instant AP-205 with no controller?
    Posted Aug 24, 2015 11:35 PM
    Hi Colin,
    The mesh ldart state is suspending and the 2.4GHz LED in yellow; 5GHz in green. it seem not boadcasting SSID. Please help to advise, many thanks!
    AP Swarm State :swarm_config_sync_complete
    mesh ldart State :suspending
    Config in flash :yes
    factory SSID in flash :no
    extended-ssid configured :no
    extended-ssid active :no
    Config load cnt :2
    VC Channel index :2
    IDS Client Gateway Detect :yes
    ac:a3:1e:c4:af:34# show swarm state
    ac:a3:1e:c4:af:34# show aps
    1 Access Point
    Name IP Address Mode Spectrum Clients Type Mesh Role Zone Serial # 2.4 Channel 2.4 Power (dB) 2.4 Utilization (%) 2.4 Noise Floor (dBm) 5.0 Channel 5.0 Power (dB) 5.0 Utilization (%) 5.0 Noise Floor (dBm) Need Antenna Config From Port Config Id Config Csum Ext SSID Active Age
    ac:a3:1e:c4:af:34 172.16.0.1* access disable 1 205 Portal - CM0165421 1 18 22(good) -97(good) 149E 24 3(good) -97(good) No none 0 50330 disable 8m:13s
  • 11.  RE: How to make mesh with Instant AP-225 and instant AP-205 with no controller?
    Posted Aug 25, 2015 12:24 AM
    Did you configure an SSID to broadcast?
  • 12.  RE: How to make mesh with Instant AP-225 and instant AP-205 with no controller?
    Posted Aug 25, 2015 12:32 AM
    Yes, the AP with wired uplink have SSID to boardcast, but the mesh point 2.4 LED in yellow
  • 13.  RE: How to make mesh with Instant AP-225 and instant AP-205 with no controller?
    Posted Aug 25, 2015 12:47 AM
    InstantAP 2XX (802.11ac) units are not supporting mesh.
    from the Release notes:
    How to do mesh with other instant models:
    in instantAP 1XX mesh is very simple,just add your IAP first by wire to your VC group (make sure extanded ssid is disabled) after u seeing the IAP in your middle table of AP , u may disconnect it from LAN and leave it only with AC adapter.
    Give it a couple of sec/min - and suddenly you will notice the magic (in Instant versions)
  • 14.  RE: How to make mesh with Instant AP-225 and instant AP-205 with no controller?
    Posted Aug 25, 2015 03:33 AM
    The release noted of 6.4.3.1-4.2, it should support Mesh.
    Mesh Support on 802.11ac Access Points
    Starting from Instant 6.4.3.1-4.2 release, the 802.11ac Access Points such as IAP-22x, IAP-27x, IAP-21x, and IAP-20x support Mesh configuration. For more information on Mesh IAP configuration, see the Aruba Instant 6.4.3.x-4.2 User Guide.
  • 15.  RE: How to make mesh with Instant AP-225 and instant AP-205 with no controller?
    Posted Aug 25, 2015 07:20 AM
  • 16.  RE: How to make mesh with Instant AP-225 and instant AP-205 with no controller?
    Posted Aug 26, 2015 06:43 AM
    Yes, I did follow those steps, but the mesh point AP 2.4GHz LED is still in Yellow.
    I waited around 10mins, then it works finally and 2.4 LED turn Green, Many Thanks!
    Jeff
  • 17.  RE: How to make mesh with Instant AP-225 and instant AP-205 with no controller?
    Posted Aug 27, 2015 12:16 AM
    The Yellow LED issue sometimes come up because of regulatory domains and so on.
