Frequent Contributor II
How to make traffic work locally without going back to controller?
Re: How to make traffic work locally without going back to controller?
Change your SSID to bridge mode.
Tim Cappalli | Aruba Security
Hi can we do it per ap instead of per ssid ?
Trusted Contributor I
not normally, you could create multiple AP groups to have different settings per group of APs.
what would be the exact use case?
