Does nobody knows how mannually trigger an ap failover??
In RNs under AP Communication with Controllers described :
An AP will failover to its backup controller if it fails to contact its active controller through regular heartbeats and keepalive messages, or if the user manually triggers a failover using the WebUI or CLI
I can not find how I can do this manually
Thanks in advance for your response!
