Frequent Contributor I
How to mount AP204
I have about 60 AP 204's (with dual external antennas) I need to hang in a warehouse.  Is there any specific way I should or should not be hanging the AP's?  I attached a pic of what I believe should be OK.
Re: How to mount AP204
Since you are using external antennas, it doesn't matter how you mount the actual AP.
Tim Cappalli | Aruba Security
Will the AP204 "work" with no external antennas plugged in?
There will very little signal propagation and you risk burning out the
radios.
