Occasional Contributor I
How to overcome issue of "Not enough flash/memory available" for upgrading 650 controller?
(BER2-BK-CAP-WLC650-L01) #show storage
Filesystem                Size      Used Available Use% Mounted on
/dev/mtdblock11         156.0M     80.2M     75.8M  51% /flash
none                    300.0M      4.7M    295.3M   2% /tmp
/dev/mtdblock11         156.0M     80.2M     75.8M  51% /mswitch/sap/images
/dev/mtdblock9           50.0M     30.0M     20.0M  60% /mnt/img0
/dev/mtdblock10          50.0M     24.2M     25.8M  48% /mnt/img1
(BER2-BK-CAP-WLC650-L01) #copy scp: kgodlewski ArubaOS_6xx_6.4.2.3_47524 system: partition 1
Not enough flash/memory available (70 MB needed).
Please clean flash and try again.
(BER2-BK-CAP-WLC650-L01) #dir
-rw-r--r--    1 root     root         5440 Mar 27 23:26 AUDITTRAIL-HISTORY.log
-rw-r--r--    1 root     root       150884 Apr  2 15:47 default.cfg
-rw-r--r--    2 root     root       137689 Mar 27 23:29 default.cfg.2015-03-27_23-29-07
-rw-r--r--    1 root     root       134701 Feb  9 17:28 default.cfg_msync_glbl_2015-02-09_17-28-28
-rw-r--r--    1 root     root       139889 Mar 27 23:35 default.cfg_msync_glbl_2015-03-27_23-35-09
-rw-r--r--    1 root     root       141632 Mar 27 23:37 default.cfg_msync_glbl_2015-03-27_23-37-01
-rw-r--r--    1 root     root       150888 Apr  2 10:49 default.cfg_msync_partial_2015-04-02_10-49-50
-rw-r--r--    1 root     root       150883 Apr  2 15:47 default.cfg_msync_partial_2015-04-02_15-47-29
-rw-r--r--    2 root     root       137689 Mar 27 23:29 original.cfg
Re: How to overcome issue of "Not enough flash/memory available" for upgrading 650 control
Please check the post here:  http://community.arubanetworks.com/t5/Controller-Based-WLANs/While-upgrading-the-controller-we-get-the-error-message-quot/ta-p/183290 for ideas.
If none of those work, you will have to contact TAC.  There are files that they could access and delete that may not be user-serviceable.
Colin Joseph
Aruba Customer Engineering
