Contributor II
How to prevent clients from frequently jumping VLANs
When our wireless infrastructure was put in place, a bunch of small vlans ( 3 /24 ranges for IP addresses per vlan) were created to reduce the broadcast issues at the time.
Problem we see today is that a client may be placed on a vlan, but after reconnect, it would be switched to a new one. Is there anything that could be done to prevent this from happening too quickly?
Something like 'sticky vlan'?  If not, I guess we could increase the range of ip addresses in a particular vlan, and then reduce the number of them?
Thanks in advance.
Re: How to prevent clients from frequently jumping VLANs
Take a look at this:
http://community.arubanetworks.com/t5/Validated-Reference-Design/Single-VLAN
-Architecture-for-WLAN/ta-p/257196
Tim Cappalli | Aruba Security
Thanks in advance.
What mechanism is being used to assign VLANs for your devices?
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Contributor II
We use external DHCP.  This is for students, so they get lumped into the same group regardless of location.
Single VLAN is the way to go, but not ready to redo the whole thing.
What is wrong with getting a different VLAN when a student reconnects?
Contributor II
Internal addresses are matched to an external address via NAT. It seems that the frequency of them jumping vlans gets them a different internal address and hence a new NAT translation is created. But the original stays put for a while. Also, easier to track down.
Thanks.
What mechanism on the controller is assigning the VLAN?
