Contributor II
How to report Total Clients by Total MB Used instead Top Clients by Total MB Used
Hi all,
I'm a newbie on the Airwave, and I have a problem with Airwave's report.
Specifically, I want to create a report that list all client with total mb used instead just top clients.
How can i do it?
Many thanks for help.
Re: How to report Total Clients by Total MB Used instead Top Clients by Total MB Used
You can run a client session report for this. One thing to include in the definition is,
Under Advance option click on show and set Include details about every session and Include details about every client to yes.
Now you can specify the time range and run the report.
Note: Since we are including all the data for client, it would be better to divide and run the report. I.e. if you are running for a month divide it to week and run.
Vishnu
If my post helped you, don't forget to give kudos ;)
Contributor II
Hi Vishnu,
May i had described no too clearly. I'm sorry for that. But commonly, report will show top 10 client with Total MB Used . I need increase more than 10 so "Number of items to include in Client Session ranked list (Greater than or equal to 1)" is what is need :)
And one more question: How can i export top services/application that user  had used ? (Example : user 1: facebook, youtube, http . User2: gmail,https,torrent....)
Is it that you want to increase the top numbers from 10 to a different value? If so you can change the number in the field "Number of items to include in Client Session ranked list (Greater than or equal to 1): " to the number we need.
Regarding the Application you can run Traffic Analysis report(assuming you are on 8.2.6. Prior to that its call AppRF report).
Vishnu
Contributor II
Thanks Vishnu,
I've created report that i want :)
