Frequent Contributor I
How to run client usage reports on 3600 WLAN controller
Is there a way to run usage reports against clients on a 3600 WLAN controller?
Tony Marques
Re: How to run client usage reports on 3600 WLAN controller
Do you have AirWave?
Tim Cappalli | Aruba Security
No.
Reporting requires AirWave.
Is there no MIB for client usage?
