How to set priority for SSID on the same AP group ?
We need to differentiate the priority of traffic per SSID.
Someone can help me?
Contributor II
Re: How to set priority for SSID on the same AP group ?
Under QoS in Traffic Management Profile you could assign a % of time dedicatted to the SSID.
MVP
how to?
Enabling Traffic Shaping Traffic shaping is configured in an traffic management profile. In the WebUI To configure traffic shaping via the WebUI: 1. Select Configuration > All Profiles. The All Profile Management window opens. 2. Select QoS to expand the QoS section. 3. Select Traffic management profile. 4. In the Profiles Details window, select the name of the traffic management profile for which you want to configure traffic shaping. (If you do not have any traffic management profiles configured, enter a name for a new profile in the Profile Details pane, then click Add. Select the new profile from the profiles list.) 5. In the Profile Details pane, click the Station Shaping Policy drop-down list and select either default-access, fair-access or preferred-access. 6. Click Apply to save your changes
We need the explanation for the fields "Video Share", "Share Background", "Voice Share" and "Share Best-effort" fields in each SSID.
Contributor II
This maps to WMM priorities, wil only be aplicable if your client supports WMM (a few devices will mark the traffic acording to this)
