Contributor I
How to upgrade OS to 6.1.3.14
how to i upgrade firmware from  ArubaOS 5.0.3.3  to  6.1.3.14? plz i need steps?
Controller: Aruba 3600
Firmware: AOS 5.0.3.3
Thanks.
Re: How to upgrade OS to 6.1.3.14
Do you have the release notes for that version? It will guide you step by step.
Tim
Tim Cappalli | Aruba Security
Please look in the 6.1.3.14 release notes for detailed instructions on how to upgrade.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Regular Contributor II
<EDIT>
Please follow this release note.
https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_ViewDetails/Default.aspx?EntryId=15671
Sorry Boneyard I didnt noticed that, I thought I am pasting PDF link from internet.
Thanks for correction :)
Trusted Contributor I
dont think we can access your computer suman :)
Contributor I
thanks friends ,, how long it take normally?
that depends on several things, ammount of APs, connection speed to APs, how fast you type :)
not sure how many steps you exactly need, as mentioned read the release notes for that. but on average count of half an hour till an hour per step if you got everything we prepared. else it might be a little longer.
if you can i would do this on a quiet moment, after office hours in a weekend, ... so you got all the time to go through the steps.
Contributor I
that is right, i will try to do that
thanks all
Contributor I
The solution is :
first current version must be upgrade to version 5.0.4 and after that to version 6.1.3
Thanks all
