Hpe switches with Cisco APs
I have a client who wants to deploy 2x hpe switches ( JG928A) to connect 80 cisco access points to them (WAP 121).
Is it feasible to do this?
Re: Hpe switches with Cisco APs
In terms on PoE the switches are rated at 370W and the APs draw a max of 6W each.
40 x 6 = 240.
Assuming you have 40 APs on each switch, the APs would draw a max of 240W, which is fine.
Cheers
James
