Contributor I
Huawei E392u-12 and RAP5
Have any of you managed to get Huawei E392u-12 4G modem to work?
This is what I have been using and for 4G settings I have chosen "none" for now. Would like to get it to work even on 3G.
provision-ap usb-type option
provision-ap usb-dev 0x12d11506
provision-ap usb-dial ATDT*99#
provision-ap usb-init AT+CGDCONT=1,'IP','internet'
provision-ap usb-modeswitch "-v 0x12d1 -p 0x14fe –M 55534243123456780000000000000011062000000100000000000000000000"
provision-ap usb-dev 0x12d11505
provision-ap usb-modeswitch "-v 0x12d1 -p 0x14db –M 55534243123456780000000000000a11062000000000000100000000000000"
provision-ap usb-modeswitch "-v 0x12d1 -p 0x14fe –M 55534243123456780000000000000a11062000000000000100000000000000"
Contributor I
Re: Huawei E392u-12 and RAP5
And here is the answer to my own question. It's working.
provision-ap master x.x.x.x
provision-ap link-priority-cellular 20
provision-ap link-priority-ethernet 40
provision-ap usb-tty ttyUSB0
provision-ap usb-modeswitch "-v 0x12d1 -p 0x1505 -V 0x12d1 -P 0x1506 -M 55534243123456780000000000000011062000000100000000000000000000"
provision-ap usb-init AT+CGDCONT=1,"IP","internet"
provision-ap remote-ap
provision-ap reprovision ap-name xx:xx:xx:xx:xx
Contributor I
New problem.
RAP can make a connection to controller and radio comes up and stays up no problem with that.
But client can only browse internet for about 1-2 mins after radio has come up and then all data transfers just stops.
No matter is it split or tunnel. With modem attached to port0 it works perfectly so no problems with firewall rules.
Any ideas?
Btw: has anyone managed to get Huawei E353 to work?
I had my HUAWEI E392u-12 with the same problem..dammed
[Mod note: URL link removed]
have you tried to update your firmware? It maybe the problem of firmware. And my version is Huawei E392u-21, it works.
