Trusted Contributor I
Hybrid Mode Disconnects?
I'm not sure if this is pure coincidence, but it seems like every time I enabled a floor of APs to work in hybrid mode, I end up with several clients getting disconnected throughout the day.  Several colleagues and myself all connecting to the same AP, got disconnecting at the same time - twice.  I setup our MACs for debugging a couple of weeks ago since we were occasionally getting disconnected, and here is the message I'm seeing logged for us:
Feb 19 08:25:31 :501065:  <DBUG> |stm|  send_ageout_sta_ack 8157: Send ageout sta aa:bb:cc:dd:ee:ff ack back to AP (X.X.X.X)
Feb 19 08:25:31 :501105:  <NOTI> |stm|  Deauth from sta: aa:bb:cc:dd:ee:ff: AP X.X.X.X-aa:bb:cc:dd:ee:ff-CAP01 Reason Unspecified Failure
I opened a case with TAC and send them the tech support logs from immediately after this occured.  I thought I'd see if anyone else here has come across this behavior or can decrypt the above error message?
If a reply adequately addresses your issue, please click on the "Accept as Solution" and "Give Kudos" button so this information can benefit other users.
Re: Hybrid Mode Disconnects?
Both of these messages are nornal part of aging out a station and not related to why the station connection failed - sorry.
send_ageout_sta_ack;
The AP tells the controller the staion has gone away, and this mesage is saying the controller got that message and is sending an ack to the AP so its ok for the AP to delete the staion from its tables.
Deauth from STA - this started the process off the AP received a deauth so started to delete the station
Thanks for the explanation.
This is an incredibly frustating occurence and I was hoping these messages pointed to the root cause.
I'd like to provide an update regarding this issue.
I just realized (doh!) that the AP 105's don't support hybrid mode.  The ArubaOS 6.2 release notes mention that AP 105s now support hybrid mode.  I believe it is now reasonable to say that yes, there are definitely issues with configuring AP 105s in hybrid mode as it's not supported prior to 6.2.0.3! :smileyembarrassed:
