Hyper V settings for Mobility Master?
Hello I'm not able to connect my MC to MM (8.2.0.2) in Hyper V. Also VRRP between MM's is not working. I know you have to enable promiscious mode in VMWARE, but we use HYPER V. It's not clear to me what i have to do to get this working. The network routing is ok.
Re: Hyper V settings for Mobility Master?
Did you look at the 8.2.x install guide starting on page 52?
Now i did, also i had to reinstall the servers with these settings. Works now.
