Frequent Contributor II
I Need Avaya handset Configuration template as Roaming VRD didn't contain any Avaya template?
I want the best configuration for using Avaya Wireless IP-Phones as I can't find it and thanks
Re: I Need Avaya handset Configuration template as Roaming VRD didn't contain any Avaya template?
I have attached a document , its a little bit old doc but should get you through ...I used it for an Aruba wireless deployment using Avaya phones and those worked with no issues with these settings.
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Thansk Victor I can see taht I should use SVP in acl session but what about the TOS value should I change it to 46 as I migh have no access to the avaya manger and is there is any changes in the new OS and avaya new OS?
You should match it with the same value that is being use across your infrastructrure
Thank you
Victor Fabian
