Occasional Contributor I
I am in need of some help soon please
We currently had our remote master revert back to the 6.1.3 code and we lost all the configuration.  I have been working with Aruba Support and we are unable to get the Rap's back up.  Currently this is a 620 aruba controller that controls just our raps.  I believe that we are just missing a piece of configuration but Aruba Support has been able to rebuild the box but it is not working we need to see why it is not working.  I believe that we just have something turned off or missing.  Can anyone help.
Re: I am in need of some help soon please
We would be just guessing here.  Aruba Support is the way to go.  Reverting back to 6.1 is an advanced topic and you are in the proper hands to troubleshoot it working with them.
If you feel like you are not getting anywhere, you can ask to have your case escalated.
Colin Joseph
Aruba Customer Engineering
Thank you I will continue to work with them and have the ticketed escalated.
