I can not be escaped from CPBOOT.
ARUBA800 Used.
In GUI BOOTPARAMETER chose a different one.
Will Continue from the next reboot.
CPBOOT Not able to climb out of.
Enables the use of GUI want to go.
What can I do?
Please help me.
Re: I can not be escaped from CPBOOT.
Please go to the URL here:  http://support.arubanetworks.com/ArubaOSKB/tabid/111/Default.aspx and search for cpboot for some ideas.
