Contributor I
I have AP275 connected directly to Controller 620 on POE port provisioned but came up as inactive?
I have AP-275 connected directly to Controller 620 on POE port access provisiond and Give Flag Inactive how to solve this issue?
Re: I have AP275 connected directly to Controller 620 on POE port provisioned but came up as inactiv
Is your AP-275 running 6.4 code?
Tim Cappalli | Aruba Security
Contributor I
yes Exactly
Have you provisioned the AP?
Contributor I
yes I have another AP -105  worked normally on the AP group I created
Do you have LLDP enabled on the interface?
Tim
Contributor I
Yes I Enbaled LLDP recive and transmit and MED
Please take a look at the system logs (show log system 50) and see if there
is any information there.
Contributor I
I found this
Feb 25 16:10:58 :306510:  <WARN> |publisher|  Dropping message from 8212 for service '77 (service not found)'
Feb 25 16:18:43 :306510:  <WARN> |publisher|  Dropping message from 8212 for service '77 (service not found)'
Feb 25 16:19:49 :306510:  <WARN> |publisher|  Dropping message from 8212 for service '77 (service not found)'
Feb 25 16:20:02 :303022:  <WARN> |AP ac:a3:1e:c0:14:ec@192.168.0.2 nanny|  Reboot Reason: No reboot message found.
Feb 25 16:24:30 :306510:  <WARN> |publisher|  Dropping message from 8212 for service '77 (service not found)'
Feb 25 16:25:16 :306510:  <WARN> |publisher|  Dropping message from 8212 for service '77 (service not found)'
Use a 802.3at PoE adapter to power up your AP275 instead of connecting directly to the 620 PoE 802.3af port.
I faced similar issue before and it was resolved using the 802.3at PoE adapter. Looks like the 620 controller PoE port does not meet the PoE requirements of the AP275, under power.
Raymond.
