Frequent Contributor II
I have Captive portal on Controller issue I got redirected once and then login without redirection ?
I used captive portal on controller and it wored once very good but once I got internet access I disconnected and connected again with no redirection I used INI role guest and default gest and mac guest and I noticed any user connected t another open ssid and connect on guest can connect withno cp redirect ?
Re: I have Captive portal on Controller issue I got redirected once and then login without redirecti
to be clear, you authenticate once by processing captive portal, you disconnect/reconnect and you get straight internet access?
This might be due to your user not being aged out from the controller.
I would look at the user-idle timeout.
show aaa timers (default is 5 min).
Also, if you process captive portal, any other user who connects gets straight internet?
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACCA
[If you found my post helpful, please give kudos!]
