Frequent Contributor I
I have a 7030 controller with ap 215's that are using only channel 44 and 48 on the a band
I have a 7030 controller running 6.4.2.6 code with 11 AP 215's attached.   what I have noticed is that they are all using channel 44 or 48 on the a band.   The B band they are using 1,6,11 as I would expect.
what would be the cause of this?
Re: I have a 7030 controller with ap 215's that are using only channel 44 and 48 on the a band
- What regulatory domain?
- Are you using 80 mhz channels (E)?
- Do you have ARM Client-Aware enabled (it is on by default).
the regulatory domain is JP3
yes client aware is enabled,
I thought 80mhz channels where not available but I just checked and it has been anabled.
You should see what allowed channels are by doing this:
show ap allowed-channels ap-name <name of ap>
Then you should probably download the latest DRT (Downloadable Regulatory Table) to properly enable the AP215 for the Japan regulatory domain:  https://support.arubanetworks.com/DownloadSoftware/tabid/75/DMXModule/510/EntryId/18212/Default.aspx
(oajamc01w) #show ap allowed-channels ap-name hajj103w
Allowed Channels for AP "hajj103w" Country Code "JP3" Country "Japan"
PHY Type Allowed Channels
802.11g (indoor) 1 2 3 4 5 6 7 8 9 10 11 12 13
802.11a (indoor) 36 40 44 48 52 56 60 64 100 104 108 112 116 120 124 128 132 136 140
802.11g (outdoor) 1 2 3 4 5 6 7 8 9 10 11 12 13
802.11a (outdoor) 100 104 108 112 116 120 124 128 132 136 140
802.11g 40MHz (indoor) 1-5 2-6 3-7 4-8 5-9 6-10 7-11 8-12 9-13
802.11a 40MHz (indoor) 36-40 44-48 52-56 60-64 100-104 108-112 116-120 124-128 132-136
802.11g 40MHz (outdoor) 1-5 2-6 3-7 4-8 5-9 6-10 7-11 8-12 9-13
802.11a 40MHz (outdoor) 100-104 108-112 116-120 124-128 132-136
802.11a 80MHz (indoor) 36-48 52-64 100-112 116-128
802.11a 80MHz (outdoor) 100-112 116-128
802.11a (DFS) 52 56 60 64 100 104 108 112 116 120 124 128 132 136 140
looks to be like it should be ok.
Well,
What is the regulatory domain assigned to those access points and have any channels been removed from it?  If not, you should open a TAC case.
I did not even check to see what channels where allowed  in the config!  that was the issue the only options a 40, 44, and 48    so ..... will have to make that change.    Thanks for your replies.
