Frequent Contributor I
I have a 8.3 MM with 2 controllers attached, how do I delete AP's
I have 8 AP's the incorrectly connected to my lab MM controllers,  they have been redirected to the correct place but now I see 8 down AP's on my MM.   How do I delete them?
Re: I have a 8.3 MM with 2 controllers attached, how do I delete AP's
clear gap-db
https://www.arubanetworks.com/techdocs/ArubaOS_83_Web_Help/Web_Help_Index.htm#ArubaFrameStyles/1CommandList/clear.htm?Highlight=clear%20gap-db
Thanks Colin, that did it.
